Transistors in darlington conguration
used as touch sensor
darlington finger led magic resistor touch Transistor
Tim
The Darlington circuit contains two connected transistors. Operation can be described by a cascade, wherein the rst transistor serves as a preamplier of the second transistor. The achieved gain is approximately the product of the two individual gains of the transistors used. To let the yellow LED light up, only a few microampere into base are needed. The achieved current amplication is that high, that applying a ngertip at the seperately crossed-brick is enough to get a current ow through 100 kOhm resistor into the base to let the LED light up. You do not need to worry about your health, because the current is not noticeable.
Art. 113638
Art. 113649
Anzahl: 3
Art. 113675
